Hi, prof Yu and brother Liu
i am reading your work named "Two-step homogenization of textile composites using mechanics of
structure genome". In section 4, a beam is used to be an example, and the obtained effective properties are preparations for the beam, but i want to konw how do you assign the properties for the beam, for example , you establish a beam model in ABAQUS , create engeneering constants with the effective properties, then create a composite section or directly homogenized section and assign it to the beam?or there is any other ways? i just want to find a way to apply your contributions for my work, thank you!
