Fouzia Noor @ on
VABS is running, but does not generate .k file.
I am able to run VABS, it generates the msh file also, but does not generate the input .k file.
It says its generating it, but never pops up or creates:
Can I get some idea where is it going wrong?
It is because the system can not find VABSIII.exe in the current folder. If you already have VABSIII.exe installed somewhere, please set the path so that the scripts knows where to invoke VABSIII.exe. You also need to put the license file in the folder where you run your scripts. By the way, please ask your question inside Prof. Yu's group instead at https://cdmhub.org/groups/yugroup/forum.
