ANSYS command can be used in PREVABS?
Hello, I am currently using ANSYS-GUI PREVABS to do the composite blade lamination. But I need to do many more data, so could I use the ANSYS APDL command to control the prevabs. Or use other soft to achieve use code to control the lamination.
Thank you, and I look forward to hearing from you.
Fang Jiang @ on
Hello. The ANSYS-GUI is based on APDL. The macro files in the download package are mostly the APDL command. This means it is open to be modified for specific purpose.
